[Mapguide-trac] [mapguide-trac] #2440: Maestro - Diff Confusion with encoding and whitespace
trac_mapguide at osgeo.org
Thu May 1 00:20:00 PDT 2014
Reporter: crispinatime | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-6.0
Component: Maestro | Version:
Severity: minor | Keywords:
External_id: |
The "Diff" capability in Maestro is very powerful - but also slightly
confusing on a couple of elements.
1) XML Encoding
When opening a resource e.g. .LayerDefinition in XML mode I see the first
line as:
<?xml version="1.0"?>
If I then edit the XML and use the Diff function it highlights the first
line as red and says that the actual source was
Implying the XML editor is stripping the encoding before showing the text
XML and firing a dirty state
2) Whitespace
If I have a vector .LayerDefinition resource with a filter, and add a
space at the end of the filter when opened in XML mode then I would expect
that line to be highlighted as different in the Diff viewer. It is not.
Neither element is major here, just some finesse if possible.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2440>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
