[Mapguide-trac] [mapguide-trac] #2443: Overhaul MgCooker UI
trac_mapguide at osgeo.org
Tue May 6 12:25:38 PDT 2014
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Keywords:
External_id: |
The current MgCooker UI has several problems:
* The UI bleeds global and map-specific tiling settings and it is not
clear which is global and which is map-specific.
* The default tile generation method is flawed (#1801, #1999). The
official method should be the only method available.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2443>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
