[Mapguide-trac] [mapguide-trac] #2443: Overhaul MgCooker UI
trac_mapguide at osgeo.org
Wed May 7 02:16:49 PDT 2014
Reporter: jng | Owner: jng
Type: enhancement | Status: closed
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Resolution: fixed
Keywords: | External_id:
Comment(by jng):
Cannot do much about the global/map-specific settings. To make this work
properly pretty much requires a full rewrite of MgCooker. Better be safe
to just optimize for the common use-case (tiling a single map).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2443#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
