[Mapguide-trac] [mapguide-trac] #1635: Fusion editor defects and loose ends
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 21 20:15:19 PDT 2014
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-5.1
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
Description changed by jng:
Old description:
> This ticket is an umbrella ticket for the fusion editor
>  * ~~Delete button in widget configuration dialog does not remove the
> underlying widget from the widget set~~
>  * The the map editor needs to be re-designed as it is currently
> hardcoded for certain map providers. Most particular, it will only allow
> 1 MapGuide map provider (and a choice of Bing/Google/Yahoo providers).
> Thus the editor prevents the ability to have a MapGroup with multiple
> MapGuide maps in it (eg. A dynamic map definition and a tiled map
> definition together)
>  * ~~Add a new validation rule that checks if any Map Definitions conform
> to the Popular Visualisation Mercator coordinate system if it is part of
> a MapGroup that also has a Bing/Google/Yahoo provider in it.~~
>  * Add a new validation rule that verifies names of resident widgets
> against known DOM element ids of the template index.html file.
New description:
  * The the map editor needs to be re-designed as it is currently hardcoded
 for certain map providers. Most particular, it will only allow 1 MapGuide
 map provider (and a choice of Bing/Google/Yahoo providers). Thus the
 editor prevents the ability to have a MapGroup with multiple MapGuide maps
 in it (eg. A dynamic map definition and a tiled map definition together)
 to the Popular Visualisation Mercator coordinate system if it is part of a
  * The selection color picker should support alpha components.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1635#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
