[Mapguide-trac] [mapguide-trac] #2450: Improve Composite	Symbolization dialog
    trac_mapguide at osgeo.org
    Fri May 23 03:39:18 PDT 2014
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  Maestro-6.0
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 * Move the inline Symbol Definition editor out to a separate dialog window
  * Show the Symbol Name in addition to the Symbol Component type
  * Add pre-defined inline symbol components that can be added to the
 symbol components list
     * Solid Fill
     * Solid Line
     * Point
     * Point Text Label
     * Line Text Label
     * Polygon Text Label
  * Move the parameter override property grid to between the component list
 and the preview image
  * Update the parameter override property grid to
     * Show the display name of any symbol parameter override
     * Add a toolbar button that can show the full parameter definition for
 a selected parameter override
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2450>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
