[Mapguide-trac] [mapguide-trac] #1637: Show Current Selection of a Multiple Feature Selection
trac_mapguide at osgeo.org
Wed Apr 8 07:28:30 PDT 2015
Reporter: steveg | Owner:
Type: enhancement | Status: new
Priority: low | Milestone: 3.1
Component: General | Version: 2.2.0
Severity: trivial | Keywords: selection
External_id: |
Changes (by jng):
* milestone: => 3.1
Comment:
Now that QUERYMAPFEATURES for all intents and purposes works as originally
designed (there has been many design/implementation defects), I've got an
easy idea on how to do this. We can implement sub-selections as renderings
of transient (temporary) selections.
We can render transient selections by simply issuing a v2.6.0
QUERYMAPFEATURES with PERSIST=0 and with a different selection color,
sending up the selection XML fragment of the current feature and require
an inline selection image as part of the response, which we can then
overlay on top of the current map image.
We can send this request on any change of map view or change of active
feature in the property palette. However, because it is transient it means
that if you plot the map there will be no active sub-selection included as
we never persist that active sub-selection server-side.
How does that sound?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1637#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
