[Mapguide-trac] [mapguide-trac] #2579: Symbols are rotated with plot to HP printer landscape
trac_mapguide at osgeo.org
Thu Dec 10 00:57:54 PST 2015
Reporter: zhanga | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 3.0.0
Severity: trivial | Keywords:
External ID: |
This defect happens on Autodesk Map 3D. But it is an issue of Stylize
Engine. The detail step is:
1. Open Autodesk Map 3D
2. Go into paper space and select a Landscape paper size
3. Plot to an HP plotter
Expected result: Drawing will plot the drawing as defined.
Actual result: The symbols in the legend are rotated 90 degrees
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2579>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
