[Mapguide-trac] [mapguide-trac] #2580: C1001 internal error building Oem/lib_json with VS2015 Update 1 in Release|x64
MapGuide Open Source trac_mapguide at osgeo.org
Sat Dec 12 05:58:35 PST 2015
Release|x64
   Reporter:  jng           |      Owner:
       Type:  defect        |     Status:  new
   Priority:  low           |  Milestone:  3.1
  Component:  Build System  |    Version:
   Severity:  trivial       |   Keywords:
External ID:                |
 Building Oem/lib_json in VS 2015 update 1 will cause a C1001 error in
 Release|x64
 The culprit is the ClCompile/AssemblerOutput setting of
 AssemblyAndSourceCode which causes this error.
 Removing this setting fixes the issue
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2580>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
