[Mapguide-trac] [mapguide-trac] #2527: mapguide init script use log_daemon_msg and log_end_msg which are not defined in Centos 6
trac_mapguide at osgeo.org
Wed Feb 11 06:48:40 PST 2015
defined in Centos 6
Reporter: gabrimonfa | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version:
Severity: trivial | Keywords:
External_id: |
Comment(by gabrimonfa):
I'm not really an expert on the topic.
"log_daemon_msg" may be replaced with a simple "echo -n" (as in other init
scripts).
"log_end_message" gives different results in debian/ubuntu whether the
argument is 0 or greater than 0 and usually is used with the exit code of
a previous command.
If called with 0 it shows a success message, otherwise a failure message.
However in our script it is always called with 0 as argument, so it may be
replaced by "log_success_msg" which is supported on both ubuntu and
centos.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2527#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
