[Mapguide-trac] [mapguide-trac] #2538: MgMap fails to initialize properly from linked tile set if both coordinate systems match
trac_mapguide at osgeo.org
Wed Feb 18 05:54:07 PST 2015
systems match
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: 3.0
Component: General | Version:
Severity: trivial | Keywords:
External_id: |
When attempting to view a Map Definition that is linked to a tkle set in
the AJAX Viewer, the viewer will fail to losd due to a null map extent.
The reason we have a null map extent is because when we initialize an
MgMap from a Map Definition that links to a tile set, if both coordinate
systems are the same, we are forgetting to set the map/data extents and
center members, which results in a null map extent when retrieved
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2538>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
