[Mapguide-trac] [mapguide-trac] #2541: Cannot connect to WMS service after editing configuration document
trac_mapguide at osgeo.org
Thu Feb 26 14:33:27 PST 2015
Reporter: gBecker | Owner: jng
Type: defect | Status: new
Priority: medium | Milestone: 3.0
Component: Maestro | Version:
Severity: critical | Keywords:
External_id: |
When editing the configuration document of a WMS FeatureSource in MGOS 3.0
via the editor, the connection to the WMS server fails. Hitting the "Test
Connection"-Button results in an unclassified error.
<2015-02-26T11:44:53> 15904 MapGuide Maestro v6.0.0.8244 ::1
Administrator
Error: Resource data was not found: MG_USER_CREDENTIALS
StackTrace:
- MgResourceServiceHandler.ProcessOperation() line 80 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpDeleteResourceData.Execute() line 101 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\resource\OpDeleteResourceData.cpp
- MgServerResourceService.DeleteResourceData() line 1917 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgApplicationRepositoryManager.DeleteResourceData() line 1065 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
- MgTagManager.GetTag() line 372 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\resource\TagManager.cpp
<2015-02-26T11:44:53> 18132 MapGuide Maestro v6.0.0.8244 ::1
Administrator
Error: Problem:\nThe application encountered a problem and could not
finish the operation you just requested properly.\n\nSolution:\nIf it\'s
the first time you met this problem, try again or restart the application
/ session; otherwise, describe the steps to reproduce this problem to the
server administrator for suggestions.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
- MgServerFeatureService.TestConnection() line 244 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
- MgFdoConnectionManager.Open() line 333 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
I've also recognized that all entries in the "Select FDO Provider" box
exists twice when you have another connection to an older MGOS version
aside a MGOS 3.0 server connection in Maestro. For example:
"OSGeo FDO Provider for WMS" and "WMS Provider"
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2541>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
