[Mapguide-trac] [mapguide-trac] #2528: Maestro API cleanup
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jan 20 06:19:29 PST 2015
   Reporter:  jng      |       Owner:  jng
       Type:  task     |      Status:  new
   Priority:  low      |   Milestone:  Maestro-6.0
  Component:  General  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 This is an umbrella ticket for general cleanup of various bits of the
 Maestro API:
 A rough list of things that need to be done:
  * Remove the FLEE-based Expression Engine API. This feature isn't
 advertised much and performing feature queries with computed properties
 achieves the same effect.
  * Remove ArgumentParser class. There are nuget-fetchable and battle-
 tested libraries that do a better job.
  * Reference NetTopologySuite proper from NuGet instead of our internal
 ILMerged NTS assembly
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2528>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
