[Mapguide-trac] [mapguide-trac] #2563: Cannot make v3.0.0 untiled Map Definitions
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jul 9 04:50:15 PDT 2015
   Reporter:  jng      |      Owner:  jng
       Type:  defect   |     Status:  new
   Priority:  low      |  Milestone:  Maestro-6.0
  Component:  Maestro  |    Version:
   Severity:  trivial  |   Keywords:
External ID:           |
 Create a v3.0.0 Map Definition using the M4 release. Do not add any tiled
 layers.
 Saving fails with a content model error because the UI does not let you
 specify an option that maps to the TileSetSource.None value.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2563>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
