[Mapguide-trac] [mapguide-trac] #2564: Feature Source XML doesn't properly update when switching to unmanaged files in editor
trac_mapguide at osgeo.org
Thu Jul 9 04:52:02 PDT 2015
files in editor
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone: Maestro-6.0
Component: Maestro | Version:
Severity: trivial | Keywords:
External ID: |
1. Create a new file-based Feature Source.
2. Browse to an aliased file.
3. Switch to unmanaged files.
Expect: The aliased file path to be in the Feature Source XML
Get: The aliased file path is not in the Feature Source XML. The file path
has to be manually edited for the changes to register in the XML.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2564>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
