[Mapguide-trac] [mapguide-trac] #2520: JenkinsCI/vagrant loose ends for 3.0 release cycle
trac_mapguide at osgeo.org
Thu Jul 9 05:15:19 PDT 2015
Reporter: jng | Owner: jng
Type: task | Status: new
Priority: low | Milestone: 3.0
Component: Build System | Version:
Severity: trivial | Resolution:
Keywords: | External ID:
Description changed by jng:
Old description:
> * Update trunk Fusion app.version to 3.0.0 in build.xml. The version is
> still 2.6.0 and is causing the buildtools package to not be copied to the
> build artifact directory
> * Run the mgserver test suite with a file parameter and configure a
> xUnit report task to report on the test output file
> * Also invoke the web tier test suite and log/report on its results.
> This requires us to be able to programatically configure up a MapGuide
> environment to run the tests in, so this item sort of depends on #2498
New description:
* ~~Update trunk Fusion app.version to 3.0.0 in build.xml. The version is
build artifact directory~~
* Run the mgserver test suite with a file parameter and configure a xUnit
* Also invoke the web tier test suite and log/report on its results. This
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2520#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
