[Mapguide-trac] [mapguide-trac] #2574: postgis/mssql datetime properties in properties panel show as null
trac_mapguide at osgeo.org
Wed Oct 14 19:02:13 PDT 2015
Reporter: Jamo | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: Map Agent | Version: 3.0.0
Severity: trivial | Keywords: PostGis, MapAgent
External ID: |
Upon selecting a feature with a postgis dateTime value the dateTime value
is returned as null to the selection panel from the map agent.
PostGis Table:
-- Table: gisgeom.plndevapp
-- DROP TABLE gisgeom.plndevapp;
CREATE TABLE gisgeom.plndevapp
fid bigserial NOT NULL,
xfmuuid character varying,
id character varying(255),
landuse character varying(255),
approved_dt timestamp without time zone,
supportingfiles text,
geom geometry,
CONSTRAINT plndevapp_pkey PRIMARY KEY (fid),
CONSTRAINT enforce_dims_geom CHECK (st_ndims(geom) = 2),
CONSTRAINT enforce_srid_geom CHECK (st_srid(geom) = 28356)
WITH (
OIDS=FALSE
ALTER TABLE gisgeom.plndevapp
OWNER TO "GIS_ADMIN";
single data row
INSERT INTO gisgeom.plndevapp(
fid, xfmuuid, id, landuse, approved_dt, supportingfiles, geom)
VALUES (76,"","DP26-12","BRISBANE CONTAINER TERMINALS AMENDMENTS TO
DP10-11","2012-11-20
10:36:27","<supportingFiles><file><file>A1805411</file><fileType>objective</fileType><status></status><comment>Consent
Notice</comment></file><file><file>fA237425</file><fileType>objective</fileType><status></status><comment>Consent
Notice</comment></file></supportingFiles>","0101000020C46E00002D06141A4C9C1F41D7DC34DA159A5A41");
Discussion on nabble: [http://osgeo-org.1560.x6.nabble.com/Mapguide-3-0
-and-postgis-mssql-datetime-properties-td5229375.html]
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2574>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
