[Mapguide-trac] [mapguide-trac] #2575: MapGuide 3.0 Instant Setup - Admin Password
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 22 17:47:53 PDT 2015
 Reporter:  jeffreyrushlow           |        Owner:
     Type:  defect                   |       Status:  new
 Priority:  low                      |    Milestone:
Component:  General                  |      Version:  3.0.0
 Severity:  trivial                  |   Resolution:
 Keywords:  instant set-up admin id  |  External ID:
Comment (by jng):
 Default id/password has always been the same.
 If you've running InstantSetup in a place that already has MapGuide
 installed, make sure you've specified different port numbers in the
 InstantSetup utility to make sure that your 3.0 web tier isn't
 communicating with your older MapGuide Server by mistake.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2575#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
