[Mapguide-trac] [mapguide-trac] #2733: New icons in slate template
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 3 02:31:50 PDT 2016
 Reporter:  geopedro          |        Owner:
     Type:  task              |       Status:  closed
 Priority:  medium            |    Milestone:  Maestro-6.0
Component:  Fusion Templates  |      Version:  2.6.0
 Severity:  major             |   Resolution:  invalid
 Keywords:  icons             |  External ID:
Changes (by jng):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 The templates all reference a PNG sprite (`icons.png`) that contains all
 the icons.
 This sprite is built using this PHP script:
 https://trac.osgeo.org/fusion/browser/trunk/utils/imagestrip.php
 So if you want to replace an icon from the template, replace the
 corresponding icon file under `$TEMPLATE/images/icons` and then run the
 `imagestrip.php` script at that directory to generate a new `icons.png`
 sprite with your replacement icon(s)
 On a side note, please use the mapguide-users mailing list in the future
 for such questions.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2733#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
