[Mapguide-trac] [mapguide-trac] #2584: SELECTFEATURES on SQL Server Spatial data source returns no geometry types/geometric types when specifying properties
trac_mapguide at osgeo.org
Fri Jan 15 09:29:27 PST 2016
Reporter: morkl | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: Feature Service | Version: 3.0.0
Severity: trivial | Keywords:
External ID: |
I'm not sure if this is an FDO problem or a MapGuide problem, but I'll
start here and see where it leads.
We are starting to add support for SQL Server Spatial in our products, and
have run into a problem when selecting features.
Selecting features without specifying properties works as expected:
http://localhost/mapguide30/mapagent/mapagent.fcgi?OPERATION=SELECTFEATURES&VERSION=1.0.0&RESOURCEID=Library://Path/To/Data/Source.FeatureSource&CLASSNAME=dbo:MY_VIEW_NAME
<xs:element name="GEOM" type="gml:AbstractGeometryType"
fdo:hasMeasure="false" fdo:hasElevation="false" fdo:srsName="Default"
fdo:geometricTypes="point curve surface " fdo:geometryTypes="point
multipoint linestring multilinestring curvestring multicurvestring polygon
multipolygon curvepolygon multicurvepolygon ">
However, selecting features and specifying properties returns empty
geometricTypes and geometryTypes:
http://localhost/mapguide30/mapagent/mapagent.fcgi?OPERATION=SELECTFEATURES&VERSION=1.0.0&RESOURCEID=Library://Path/To/Data/Source.FeatureSource&CLASSNAME=dbo:MY_VIEW_NAME&PROPERTIES=GEOM
fdo:geometricTypes="" fdo:geometryTypes="">
DescribeFeatureSchema returns the expected geometricTypes and
geometryTypes:
http://localhost/mapguide30/mapagent/mapagent.fcgi?OPERATION=DESCRIBEFEATURESCHEMA&VERSION=1.0.0&RESOURCEID=Library://Path/To/Data/Source.FeatureSource&SCHEMA=dbo&CLASSNAMES=MY_VIEW_NAME
multipolygon curvepolygon multicurvepolygon "/>
The empty strings cause MaestroAPI to throw an ArgumentException in
GeometricPropertyDefinition.ProcessGeometricTypes, making it difficult for
us to use MaestroAPI for SQL Server Spatial data sources at the moment.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2584>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
