[Mapguide-trac] [mapguide-trac] #2596: Constant crashes under high load/many concurrent requests
trac_mapguide at osgeo.org
Tue Jun 21 23:47:32 PDT 2016
Reporter: andymorf | Owner:
Type: defect | Status: new
Priority: high | Milestone: 3.1
Component: Server | Version: 3.0.0
Severity: blocker | Resolution:
Keywords: crash, high load | External ID:
Comment (by jng):
My current findings thus far.
I was able to finally reproduce this problem and am strongly suspecting
that it is some kind thread-safety issue around strings.
This error from the provider
c_KgOraSelectCommand.Execute : ERROR: FindClassDefinition() return NULL
is most likely because it was fed a corrupted string as a result of
intense multi-threaded usage.
I found an old mapguide-internals thread which highlighted some pitfalls
around STL string usage in a multi-threaded environment (http://osgeo-
org.1560.x6.nabble.com/std-string-not-thread-safe-on-Linux-
td4210940i20.html)
Which leads me to suspect it is some thread-safety issue around `MgUtil`
and its static `sm_classNameQualifier` STL string member
(https://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Foundation/System/Util.cpp#L1232).
I think corruption is being introduced by multiple threads concatting from
that same static STL string.
Why do I think this? Because this is the file where VS generally starts
breaking on when it starts access violating in my load tests. Other places
where it breaks on access violation also happen to be places that involve
an FDO class name that would've went through MgUtil one way or another.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2596#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
