[Mapguide-trac] [mapguide-trac] #2527: mapguide init script use log_daemon_msg and log_end_msg which are not defined in Centos 6
trac_mapguide at osgeo.org
Wed May 11 03:13:30 PDT 2016
defined in Centos 6
Reporter: gabrimonfa | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version:
Severity: trivial | Resolution:
Keywords: | External ID:
Comment (by gabrimonfa):
The proposed file try to address the following problems:
* define log_end_msg if not defined in lsb functions (as in Centos 6)
* define status and restart actions
* exit with failures if something goes wrong
* warn user if trying to start MapGuide and it is already running
* warn user if trying to stop MapGuide and it is not running
I've not tested it throughly in Ubuntu
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2527#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
