[Mapguide-trac] [mapguide-trac] #2747: Maestro: Display property mapping in Layer editor does not match the generated XML
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 6 05:57:55 PDT 2016
generated XML
   Reporter:  jng      |      Owner:  jng
       Type:  defect   |     Status:  new
   Priority:  low      |  Milestone:  Maestro-6.0
  Component:  Maestro  |    Version:
   Severity:  trivial  |   Keywords:
External ID:           |
 Per this thread: http://osgeo-org.1560.x6.nabble.com/Out-of-Order-
 SelectionPanel-js-td5288902.html
 I tried reproducing the problem with data provided by Gordon. It turns out
 that the layer properties I'm selecting to show does not match the
 generated XML in terms of display order.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2747>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
