[Mapguide-trac] [mapguide-trac] #2587: Docker-based Linux builds for 64-bit
MapGuide Open Source trac_mapguide at osgeo.org
Wed Oct 26 02:37:25 PDT 2016
 Reporter:  jng          |        Owner:  jng
     Type:  enhancement  |       Status:  new
 Priority:  low          |    Milestone:  3.1
Component:  General      |      Version:  3.0.0
 Severity:  trivial      |   Resolution:
 Keywords:               |  External ID:
Comment (by jng):
 Hi Bruce,
 This ticket isn't related to the mapguide docker image I've put on docker
 hub. It's more an idea of a CentOS/Ubuntu docker image (pre-loaded with
 all the required dev dependencies) that I can spin up to easily build the
 MapGuide sources in a clean/reproducible manner.
 I've made an issue on your github repo about some ideas/directions you
 could take this in.
 https://github.com/brucepc/mapguide/issues/1
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2587#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
