[Mapguide-trac] [mapguide-trac] #2739: QUERYMAPFEATURES does not respect REQUESTDATA when using FEATUREFILTER instead of GEOMETRY
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 7 05:32:42 PDT 2016
instead of GEOMETRY
 Reporter:  jng                |        Owner:  jng
     Type:  defect             |       Status:  closed
 Priority:  high               |    Milestone:  3.0
Component:  Rendering Service  |      Version:  2.5.0
 Severity:  critical           |   Resolution:  wontfix
 Keywords:                     |  External ID:
Changes (by jng):
 * status:  new => closed
 * version:   => 2.5.0
 * resolution:   => wontfix
Comment:
 It doesn't respect the geometry because when LAYERATTRIBUTEFILTER is not
 passed in, it defaults to 3 (include selectable and visible layers). If
 passing selection XML, it may contain selected features that cause the
 omission to happen (and the false appearance of REQUESTDATA not being
 respected).
 To prevent this, client applications should include a LAYERATTRIBUTEFILTER
 of 0, which will disable all layer candidate filtering, and allow the
 REQUESTDATA to be respected.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2739#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
