[Mapguide-trac] [mapguide-trac] #2766: Implement RFC 157
trac_mapguide at osgeo.org
Tue Apr 11 08:00:01 PDT 2017
Reporter: jng | Owner: jng
Type: task | Status: closed
Priority: low | Milestone: 3.3
Component: General | Version:
Severity: trivial | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* owner: (none) => jng
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"9143" 9143]:
#!CommitTicketReference repository="" revision="9143"
Implement RFC 157
This adds a new overload of MgMap::Create that accepts:
- map definition id
- map name
- image width
- image height
- view center X
- view center Y
- view scale
- dpi
With this overload, the created MgMap instance can be used on the
following APIs statelessly without needing to open it first from a session
repository (via a session id and map name pair)
- MgRenderingService::QueryFeatures
- MgRenderingService::QueryFeatureProperties
- MgRenderingService::RenderMapLegend
- MgRenderingService::RenderDynamicOverlay
With this change, there is enough APIs in place from which to build a
stateless map viewer that can perform selections and does not require
creating or interacting with a session repository or resources inside it.
As an addendum to the original RFC, the MgSelectionBase::SetMap method has
also been promoted to EXTERNAL_API to allow selections from an
MgFeatureInformation to be interrogated without throwing.
A server unit test has been added to verify these new MgMap::Create
parameters stick on the map.
A series of .net unit tests have been added to exercise the aforementioned
rendering service APIs using the statelessly-created MgMap.
Fixes #2766
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2766#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
