[Mapguide-trac] [mapguide-trac] #2768: Ubuntu install script changes for better usability with docker
trac_mapguide at osgeo.org
Sat Apr 22 09:27:25 PDT 2017
Reporter: jng | Owner: jng
Type: enhancement | Status: closed
Priority: low | Milestone:
Component: Installer | Version:
Severity: trivial | Resolution: fixed
Keywords: | External ID:
Comment (by jng):
In [changeset:"9171" 9171]:
#!CommitTicketReference repository="" revision="9171"
Merged revision(s) 9163, 9166-9168 from trunk/Tools/Vagrant:
Update clean.bat and Vagrantfiles in light of stupidity introduced in
vagrant that demands the script file being referenced by the shell
provisioner configuration physically exist, even if I just want to destroy
the associated running VM!
Fix bad provision script path for centos6/x86
- Remove bash-isms from install script. This script now runs on vanilla
POSIX sh. Fixes #2760
- Add support for:
--no-service-install: To prevent automatic installation of service
scripts
--no-mgserver-start: Do not auto-start mgserver
--no-tomcat-start: Do not auto-start tomcat
--no-httpd-start: Do not auto-start httpd
All these new flags only apply if the --headless flag is specified. Fixes
#2768
Merged revision(s) 8967, 8972-8973 from branches/3.1/vagrant:
Fix release label not being properly stamped onto ubuntu install script as
it was looking for a default label that doesn't exist.
Update ubuntu install script:
- Add extra pre-requisite packages that were discovered to be required
when testing on a clean barebones Ubuntu server installation.
Remove libc6 requirement from mginstallubuntu.sh. This package will always
be present.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2768#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
