[Mapguide-trac] [mapguide-trac] #2507: Error after adding second map to Fusion
trac_mapguide at osgeo.org
Wed Jan 11 06:14:46 PST 2017
Reporter: andrewd | Owner: jng
Type: defect | Status: closed
Priority: low | Milestone:
Component: Maestro | Version: 2.5.0
Severity: trivial | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"9115" 9115]:
#!CommitTicketReference repository="" revision="9115"
Fix NRE. We should be setting the id from the MapGroup and not the
associated MapWidget that is null if it doesn't point to this MapGroup id
Fixes #2507
Ticket URL: </ticket/2507#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
