[Mapguide-trac] [mapguide-trac] #2785: Fix Linux/CMake build
trac_mapguide at osgeo.org
Fri Dec 7 15:17:38 PST 2018
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: low | Milestone: 3.3
Component: Build System | Version:
Severity: trivial | Resolution:
Keywords: | External ID:
Description changed by jng:
Old description:
> The current cmake/linux build:
> * Fails due to looking for an incorrect apache tomcat tarball
> * Non-cmake build fails because DWF Toolkit's zlib (that was recently
> updated) is missing `Makefile.am`
> * CMake build for x64 fails because DWF Toolkit does not built the x64
> timer implementation due to not defining the right preprocessor symbols.
> * Has various linting problems in the cmake_*.sh helper scripts (as
> reported by https://www.shellcheck.net/)
New description:
* ~~Fails due to looking for an incorrect apache tomcat tarball~~
* ~~Non-cmake build fails because DWF Toolkit's zlib (that was recently
updated) is missing `Makefile.am`~~
* ~~CMake build for x64 fails because DWF Toolkit does not built the x64
timer implementation due to not defining the right preprocessor symbols.~~
* ~~Has various linting problems in the cmake_*.sh helper scripts (as
reported by https://www.shellcheck.net/)~~
* CMake RPATHs are hard-coded to `lib` which is incorrect for 64-bit
(which require `lib64`)
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2785#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
