[Mapguide-trac] [mapguide-trac] #2786: CPack packaging support
trac_mapguide at osgeo.org
Wed Dec 12 07:06:09 PST 2018
Reporter: jng | Owner: jng
Type: task | Status: assigned
Priority: high | Milestone: 3.3
Component: Build System | Version:
Severity: major | Resolution:
Keywords: | External ID:
Comment (by jng):
CPack in its current form is not quite useful for us in MapGuide as a
majority of the MapGuide thirdparty libs are not built via CMake, but via
make and autotools (which currently requires a separate assist build phase
via cmake_bootstrap.sh).
CPack relies on us being able to {{{install()}}} such external library
files which is not possible in this current setup.
The best we can do here is to use the prefix defined in cmake_bootstrap.sh
as an intermediate staging are from which our CMake build "copies" from
into its CMAKE_CURRENT_BINARY_DIR staging area, that we can then proceed
to {{{install()}}} from.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2786#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
