[Mapguide-trac] [mapguide-trac] #2781: Find a way to not leak ACE/xerces headers/definitions in MapGuide common headers
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 8 22:00:34 PDT 2018
headers
 Reporter:  jng           |        Owner:  jng
     Type:  defect        |       Status:  closed
 Priority:  high          |    Milestone:  3.3
Component:  Build System  |      Version:  3.1.0
 Severity:  trivial       |   Resolution:  fixed
 Keywords:                |  External ID:
Comment (by jng):
 In [changeset:"9396" 9396]:
 #!CommitTicketReference repository="" revision="9396"
 Merged revision(s) 9393-9395 from branches/3.1/MgDev:
 Introduce a new preprocessor symbol SWIG_PUBLIC_API
 With this symbol, we #ifdef out and forward-declare as much of ACE and
 xerces types and headers in our MapGuide common headers. The only ACE
 header that is leaked out now is the header for ACE_Recursive_Thread_Mutex
 as that is present as member of several classes in the public MapGuide API
 surface.
 In our SWIG binding projects, SWIG_PUBLIC_API is defined. All other
 consuming projects do not define this symbol so they see the original set
 of ACE and xerces headers.
 This change slightly breaks the SWIG C++ glue code for .net (which used
 un-qualified list), so our internal copy of SWIG is updated to use fully
 qualified list (std::list) and our various SWIG parameter files include
 the <list> header.
 This change eliminates the need for us to maintain a patched copy of
 TSRM/readdir.h for PHP, so that is removed.
 Fixes #2781
 #2781: Remove xerces include and linker settings
 #2781: Limit the scope of these changes to Windows. Linux never had these
 conflicts, so no need to apply any of these changes there.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2781#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
