[Mapguide-trac] [mapguide-trac] #2783: Point CS-Map to its repository root
MapGuide Open Source trac_mapguide at osgeo.org
Sat Nov 17 05:01:22 PST 2018
   Reporter:  jng           |      Owner:  jng
       Type:  task          |     Status:  assigned
   Priority:  high          |  Milestone:  3.3
  Component:  Build System  |    Version:
   Severity:  major         |   Keywords:
External ID:                |
 I've been playing around with making a read-only git mirror of MapGuide.
 One of the problems with the converted mirror is that it does not have
 links to CS-Map or Fusion, so the repo is not immediately buildable.
 Git's analogue to svn externals is submodules and in order for us to be
 able to add a submodule to a git mirror of CS-Map this svn repo should be
 re-configured so that its CS-Map in {{{Oem/CsMap}}} will point to
 {{{[repo]}}} and not {{{[repo]/CsMapDev}}} as it is currently
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2783>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
