[Mapguide-trac] [mapguide-trac] #2794: CMake: Support building common libs only
trac_mapguide at osgeo.org
Wed Jan 23 05:53:00 PST 2019
Reporter: jng | Owner: jng
Type: enhancement | Status: assigned
Priority: low | Milestone: 3.3
Component: Build System | Version:
Severity: trivial | Keywords:
External ID: |
To speed up the inner dev loop of the pure swig API binding work, we
should tailor the CMake build to be able to only build the common subset
of the MapGuide source, which is:
Common/Foundation
Common/Geometry
Common/MdfModel
Common/MdfPaser
Common/PlatformBase
Common/MapGuideCommon
Web/src/HttpHandler
Web/src/WebApp
Web/src/WebSupport
And the required upstream bits
ACE
xerces
jsoncpp
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2794>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
