[Mapguide-trac] [mapguide-trac] #2799: MapGuide to recognize "application/xml" as an alternative XML mime type to "text/xml"
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 2 06:30:14 PDT 2019
"text/xml"
   Reporter:  Percy      |      Owner:  (none)
       Type:             |     Status:  new
  enhancement            |
   Priority:  high       |  Milestone:  4.0
  Component:  WMS        |    Version:  3.1.0
  Interface              |   Keywords:  "application/xml" as an alternative
   Severity:  blocker    |  XML mime type
External ID:             |
 If you make WFS 1.1.0 requests via POST with an XML body, you can set the
 content-type to "text/xml" or "application/xml" without the mapagent
 rejecting the "application/xml" request and sending back a 401
 unauthorized.
 And resultType="hits" requests via POST with an XML body as an possible
 solution in "application/xml" as a XML mime type.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2799>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
