[Mapguide-trac] [mapguide-trac] #2828: Java configuration not functional after Tomcat 9 upgrade
trac_mapguide at osgeo.org
Tue Oct 6 02:05:03 PDT 2020
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: high | Milestone: 4.0
Component: Installer | Version:
Severity: blocker | Keywords:
External ID: |
Tomcat 9 introduced some configuration changes (to address the Ghostcat
vulnerability) that makes the Java MapGuide API/viewer not functional.
* The AJP `<Connector>` node in `server.xml` is commented out. It needs
to be uncommented
* The commented node also specifies to listen on `::1`. Change this to
`127.0.0.1`
* The AJP connector in Tomcat 9 requires a shared secret between it and
the mod_jk worker. Set this value through the `secret` attribute of the
connector node
<Connector ... secret="mapguide4java" />
* Add and change the following lines in `worker.properties` to set the
shared secret
worker.worker1.host=127.0.0.1
worker.worker1.secret=mapguide4java
This is the final blocker to be cleared for the preview 2 release.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2828>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
