[Mapguide-trac] [mapguide-trac] #2826: CMake: Installed symlinks should be relative to its library
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 17 04:46:37 PDT 2020
   Reporter:  jng           |      Owner:  jng
       Type:  defect        |     Status:  assigned
   Priority:  low           |  Milestone:  4.0
  Component:  Build System  |    Version:
   Severity:  trivial       |   Keywords:
External ID:                |
 Currently a limitation of our `install_symlink` macro is that the symlink
 to install references an absolute path. As a result, these symlinks will
 break if the underlying installation prefix is different.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2826>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
