[Mapguide-trac] [mapguide-trac] #2836: MVT rendering issues
trac_mapguide at osgeo.org
Mon Apr 12 04:55:43 PDT 2021
Reporter: jng | Owner: jng
Type: defect | Status: reopened
Priority: medium | Milestone: 4.0
Component: Tile Service | Version:
Severity: major | Resolution:
Keywords: | External ID:
Changes (by jng):
* status: closed => reopened
* resolution: fixed =>
Old description:
> * We need to apply a buffer on the MVT tile region so that client
> applications can properly stitch together features that cross tile
> boundaries
> * ~~Multi-polygons that cross tile boundaries are not being rendered~~
> Multi-geometries are not supported in the vector tile spec (see:
> [https://github.com/mapbox/vector-tile-spec/tree/master/2.1#434-geometry-
> types 4.3.4 Geometry Types]), so such multi-geometries should be exploded
> into its constituent geometries
> * Geometries should be simplified at higher levels
New description:
* ~~We need to apply a buffer on the MVT tile region so that client
boundaries~~
into its constituent geometries~~
* ~~Geometries should be simplified at higher levels~~
* Certain geometries near tile boundaries are not rendering at certain
levels.
Comment:
Re-opening as this was erroneously closed as a result of the merge commit
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2836#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
