[Mapguide-trac] [mapguide-trac] #2834: Ensure all non-OL2 examples use ol.js under viewerfiles
MapGuide Open Source trac_mapguide at osgeo.org
Mon Jan 11 02:01:39 PST 2021
   Reporter:  jng      |      Owner:  jng
       Type:  task     |     Status:  assigned
   Priority:  low      |  Milestone:
  Component:  Samples  |    Version:  2.5.0
   Severity:  trivial  |   Keywords:
External ID:           |
 Currently these use a separate version of OL which is still at v4.1.
 Most devs using OpenLayers will probably not be at this version so they
 will have problems with the given code samples not lining up with expected
 results in the current OpenLayers (6.5.0)
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2834>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
