[Mapguide-trac] [mapguide-trac] #2838: MgInstantSetup updates/fixes
trac_mapguide at osgeo.org
Sat Jun 12 02:03:33 PDT 2021
Reporter: jng | Owner: jng
Type: defect | Status: closed
Priority: low | Milestone: 4.0
Component: Installer | Version:
Severity: trivial | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"9853" 9853]:
#!CommitTicketReference repository="" revision="9853"
Ensure MgInstantSetup creates the specified temp directories. Failure to
do this will cause cryptic side-effects such as failing to login to the
MapGuide Site Administrator.
Also default 64-bit checkbox to checked.
Fixes #2838
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2838#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
