[Mapguide-trac] [mapguide-trac] #2839: Do not ship MapGuideApi.jar in www/WEB-INF/lib
MapGuide Open Source trac_mapguide at osgeo.org
Thu Jun 17 07:47:07 PDT 2021
   Reporter:  jng      |      Owner:  jng
       Type:  task     |     Status:  assigned
   Priority:  low      |  Milestone:  4.0
  Component:  Web API  |    Version:
   Severity:  trivial  |   Keywords:
External ID:           |
 I've *finally* solved the issue of 403 tomcat errors on Linux with the
 soon-to-be preview 3 release of MGOS 4.0.
 However, this brings up the "problem" where none of the jsp viewer code is
 now using the non-crufty classes in `MapGuideApiEx.jar` instead of the
 crufty classes in `MapGuideApi.jar`
 Since the primary blocker of MGOS 4.0 is functional .net/java/php wrappers
 generated with vanilla SWIG, for java we are going to be generate a
 wrapper whose surface is nearly identical to `MapGuideApiEx.jar`. So to
 ease the transition to this new vanilla SWIG wrapper when it finally
 arrives, we should for the preview 3 release:
  * No longer ship `MapGuideApi.jar` in `www/WEB-INF/lib`
  * Fix all our java viewer and sample code to work against
 `MapGuideApiEx.jar`
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2839>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
