[Mapguide-trac] [mapguide-trac] #2828: Java configuration not functional after Tomcat 9 upgrade
trac_mapguide at osgeo.org
Sat Jun 19 08:57:49 PDT 2021
Reporter: jng | Owner: jng
Type: defect | Status: closed
Priority: high | Milestone: 4.0
Component: Installer | Version:
Severity: blocker | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* status: assigned => closed
* resolution: => fixed
Comment:
The issue was 2 `tomcat.conf` files being created, one with the required
secret and one without. The one without the secret was being used. The
issue was fixed by the install script writing out the `tomcat.conf` with
the required secret to the correct path.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2828#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
