[Mapguide-trac] [mapguide-trac] #2849: MgInstantSetup: IIS setup needs to apply legacy requestValidationMode="2.0" setting to mapviewernet
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 10 08:12:47 PDT 2022
 Reporter:  jng        |        Owner:  jng
     Type:  defect     |       Status:  closed
 Priority:  low        |    Milestone:  4.0
Component:  Installer  |      Version:
 Severity:  trivial    |   Resolution:  fixed
 Keywords:             |  External ID:
Changes (by jng):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"9954" 9954]:
 {{{#!CommitTicketReference repository="" revision="9954"
 Ensure legacy requestValidationMode setting is being applied for IIS/.net
 configuration. Fixes #2849
 Add new field to optionally provide a log file where setup actions are
 being logged to. Fixes #2848
 #2847: Fix 64-bit flag not being picked up due to UI not being in sync
 with underlying model
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2849#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
