[Mapguide-trac] [mapguide-trac] #2863: White or colored tiles at z=0 when using Default-TileSetDefinition
trac_mapguide at osgeo.org
Fri Mar 3 03:02:38 PST 2023
Reporter: gBecker | Owner: (none)
Type: defect | Status: new
Priority: high | Milestone: 4.0
Component: Rendering Service | Version:
Severity: major | Keywords: Version 4 Preview 4
External ID: |
In our application I use a MapDefinition with an external
TileSetDefinition of the type "Default Tile Provider". We access this
MapDefinition in our OpenLayers frontend from a map that is set to a local
coordinate system (EPSG:25832). In the TileSetDefinition I have defined
this CoordinateSystem and the scales in which I want the tiles to be
created:
500000,250000,100000,50000,25000,10000,5000,2500,1000,500,250,100
With MapGuide version 3.1.2 everything works as expected.
However, it turned out that in the latest beta version of MapGuide 4 at a
scale of 1:100 (TileCoordinate z = 0) only white or colored tiles are
created, depending on what LayerDefinition type you are using
(raster/vector).
All the other Scales are correct.
I tested this by using the MapGuide package that I created under 3.1.2 and
then loading it into MapGuide 4 Preview 4. So, it is exactly the same
configuration.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2863>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
