[Mapguide-trac] [mapguide-trac] #2864: Support ability to deny resource fetching calls to certain resources for Anonymous users in the mapagent
MapGuide Open Source trac_mapguide at osgeo.org
Tue Mar 21 05:49:24 PDT 2023
 Reporter:  jng          |        Owner:  jng
     Type:  enhancement  |       Status:  assigned
 Priority:  low          |    Milestone:  4.0
Component:  Map Agent    |      Version:
 Severity:  trivial      |   Resolution:
 Keywords:               |  External ID:
Description changed by jng:
Old description:
> To reduce the attack surface of the MapGuide Web Tier and to prevent
> unwanted leakage of sensitive connection strings in certain Feature
> Sources, we should provide the ability for admins to deny the use of
> resource fetch APIs to anonymous users.
> This could be defined as a list of resource ids or resource id prefixes
> in `webconfig.ini` that get checked against any resource id of a
> GETRESOURCE, GETRESOURCEHEADER, GETRESOURCEDATA operation executed in the
> context of an Anonymous user.
New description:
 resource fetch APIs to anonymous users on a certain set of resources
 This could be defined as a list of resource ids or resource id prefixes in
 `webconfig.ini` that get checked against any resource id of a GETRESOURCE,
 GETRESOURCEHEADER, GETRESOURCEDATA operation executed in the context of an
 Anonymous user.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2864#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
