[Mapguide-trac] [mapguide-trac] #2872: "Open any map or tile set" sample app fails to load a Map Definition that links to a XYZ tileset
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 26 07:10:02 PDT 2023
 Reporter:  jng      |        Owner:  jng
     Type:  defect   |       Status:  closed
 Priority:  low      |    Milestone:  4.0
Component:  Samples  |      Version:
 Severity:  trivial  |   Resolution:  fixed
 Keywords:           |  External ID:
Changes (by jng):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"10051" 10051]:
 {{{#!CommitTicketReference repository="" revision="10051"
 The problem with the "Open any map or tile set" sample was not actually in
 the code, it was in the SheboyganXYZ tileset we're trying to load. It had
 extents in LL84 coordinates instead of Web Mercator. The extents on this
 tileset has been fixed to match expected coordinates.
 Fixes #2872
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2872#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
