[Mapguide-trac] [mapguide-trac] #2874: Error on MgMappingUtil.StylizeLayers
trac_mapguide at osgeo.org
Tue Sep 19 05:16:09 PDT 2023
Reporter: dfanetti | Owner: (none)
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version:
Severity: trivial | Resolution:
Keywords: | External ID:
Comment (by jng):
This is more a mental note for myself when I finally give this ticket my
full attention:
My current running theory is that due to our linux builds of both MapGuide
and FDO not using [https://gcc.gnu.org/wiki/Visibility GCC symbol
visibility] (`-fvisibility=hidden`), symbols of thirdparty libs we use
(such as SQLite) are present in our final `.so` files. You can see
`sqlite3_*` symbols when doing a symbol dump of some of our `.so` files.
Because these symbols are present, I theorize that when GDAL calls PROJ
for any CS/projection functionality, PROJ's use of SQLite is hitting our
`.so` files for SQLite3 symbols instead of the normal expected SQLite3
`.so` library and this "crossing of the wires" is the cause of the
reported error:
`PROJ: SQLite3 version is 3.3.17, whereas at least 3.11 should be used`
We had this "crossing of the wires" issue in the past with the SDF
provider (looking for sqlite3 functions in the DWF Toolkit .so), but we
were able to band-aid over this problem by building the SDF provider with
`-BSymbolic`, forcing the SDF provider to look within itself for SQLite3
functions.
That kind of band-aid won't work here, we need to make these sqlite3
symbols hidden and GCC visibility attributes would be the proper way to
make sure this happens.
But I don't see adding GCC visibility attributes to MapGuide/FDO to be a
trivial task. While conceptually similar to `__declspec(dllimport)` and
`__declspec(dllexport)` on Windows, we have to make sure the proper pre-
preprocessor symbols are added to all the MapGuide/FDO projects so that we
are properly exporting and importing any given public API (just like on
Windows).
And that's a lot of projects we have to update!
Another less nuclear option (we only just want to hide our internal
sqlite3 symbols!) may be something like this:
https://stackoverflow.com/questions/61598075/hide-symbols-from-a-3rd-
party-a-file-that-is-linked-into-a-so-file
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2874#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
