[Mapguide-trac] [mapguide-trac] #2874: Error on MgMappingUtil.StylizeLayers
    trac_mapguide at osgeo.org
    Tue Aug 13 04:38:21 PDT 2024
 Reporter:  dfanetti  |        Owner:  (none)
     Type:  defect    |       Status:  closed
 Priority:  low       |    Milestone:
Component:  General   |      Version:
 Severity:  trivial   |   Resolution:
 Keywords:            |  External ID:
Changes (by jng):
 * status:  new => closed
Comment:
 Fixed in r10094 in terms of the criss-crossing symbol resolution behavior.
 However, with this change, the PostGIS support in the OGR provider is
 still somewhat flaky as I get constant errors in `Error.log` of the form:
 cursor "ogrpglayerreader0xsomememoryaddr" does not exist
 So for Beta 2 at least, the recommendation is to use the
 `OSGeo.PostgreSQL` provider instead. This will be noted as a known issue
 in the Beta 2 release notes.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2874#comment:11>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
