[Mapguide-trac] [mapguide-trac] #2881: MgDevHttpServer: Support optional host to listen on
trac_mapguide at osgeo.org
Mon Jul 29 09:26:31 PDT 2024
Reporter: jng | Owner: jng
Type: enhancement | Status: assigned
Priority: medium | Milestone: 4.0
Component: General | Version:
Severity: trivial | Keywords:
External ID: |
MgDevHttpServer is currently hard-coded to always listen on "localhost".
While this is generally the safe and correct setting, it does hamper its
usability when run inside a docker container, where you want to bind on
"0.0.0.0" to be accessible outside the docker container.
To support this, MgDevHttpServer should support an optional `--host`
parameter that controls what host the http server will listen on. If not
specified, it will assume the default value of "localhost"
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2881>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
