[Mapguide-trac] [mapguide-trac] #2883: InstantSetup: Generate wrapper script to launch tomcat if java option enabled
    trac_mapguide at osgeo.org
    Tue Sep 17 02:54:41 PDT 2024
enabled
   Reporter:  jng          |      Owner:  jng
       Type:  enhancement  |     Status:  assigned
   Priority:  low          |  Milestone:  4.0
  Component:  Installer    |    Version:
   Severity:  trivial      |   Keywords:
External ID:               |
 Currently if configuring an InstantSetup install for Java, one still has
 to manually run `Web/Tomcat/bin/startup.bat` for the Java integration to
 work.
 For extra convenience, we should generate a wrapper batch script to run
 this alongside the other batch scripts generated by this utility.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2883>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
