[Mapguide-trac] [mapguide-trac] #2886: Un-breaking of building trunk
MapGuide Open Source trac_mapguide at osgeo.org
Fri Feb 7 08:33:30 PST 2025
   Reporter:  jng       |      Owner:  jng
       Type:  task      |     Status:  assigned
   Priority:  high      |  Milestone:
  Component:  General   |    Version:
   Severity:  critical  |   Keywords:
External ID:            |
 Currently building MG trunk is broken due to upstream breaking changes
 from the CS-Map library. Due to my current focus on getting 4.0 out the
 door, the trunk has been left in a state of dis-repair for quite some
 time. Most of the "dev" work has been done on the 4.0 branch.
 Once 4.0 hits the RC stage and we have made a FDO 4.2 branch, efforts
 should be made to get trunk buildable again.
 An initial checklist:
  * FDO trunk
    * Merge in remainder of changes from adsk branch
      * SQL Server Provider: Using new ODBC driver
      * FDO Core: API changes around FdoDateTime and vertical CS support in
 spatial contexts
      * SQLite Provider: Fresh rebase on top of their code
         * However, we must be cognizant of
 [https://trac.osgeo.org/fdo/ticket/895] not happening again as this is
 what caused us to abort all of our code merge efforts for this provider.
 If this still happens, we cannot proceed.
  * MG trunk
    * Merge in everything from 4.0 branch (once at final/RC)
      * In the event of conflicts, the 4.0 branch is the winner in all
 cases.
    * Fix up broken usages of CS-Map API
    * Merge in changes from adsk branch that we previously held off on
      * MgDateTime offset support
      * Vertical CS support in spatial contexts
      * New Layer Definition schema changes and stylization engine support
 for said changes
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2886>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
