[Mapguide-trac] [mapguide-trac] #2895: Allow debug and release builds from single source tree
trac_mapguide at osgeo.org
Mon Nov 2 16:07:13 PST 2026
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: low | Milestone: 4.0.1
Component: Build System | Version:
Severity: trivial | Keywords:
External ID: |
Currently MapGuide cannot be built in both debug and release from the same
source tree because the FDO setup only allows for one set of .lib files,
which means there is debug/release cross-linkage or vice versa if one
attempts to build both debug and release.
Change the FDO layout setup so that its debug/release .lib files are in
separate directories and make sure downstream debug/release consumers
reference the correct set of .lib files.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2895>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
